Due to a change from sierra to cortina hubs I need a pair of top wishbones for a book chassis.
My original ones had a larger thread to suit the rose joint for the top mount on the hub!
Col
Col,
I have a pair of lolocost book top wishbones that I'm no longer using.
They could do with rubbing back and a lick of paint. they have bushes and crush tubes with them if they're of any use to you.
Any good?
Ned.
Lolocost use M10 bolts don't they Ned, what size joints were you using and how wide are your chassis brackets? Didn't you use a Transit M18 top joint thread, not many rose joints are bigger than that.
yup, m10 pete.
Ned.
