Long shot this one:
Anyone got a 1/4NPT (male) to 1/4BSP (male or female) adapter laying about?
My experience is that in small sizes (under 1" ) NPT and BSP threads are close enough to be interchangable.
Fred WB
[Edited on 16/3/06 by Fred W B]
yes, should fit and seal ok anyway
Okie dokie, cheers chaps
you've probably got one.
Just wrap PTFE around the threads and screw together.
If you get stuck, I'll make you one. The threads are close but not the same and with fittings that small it's easy for the threads to jam so when you come to remove them, they just snap off.
Cheers for the offer owelly. I have a lathe at home so can make one if it comes to that. I am just lazy!
Will have a go with what I have got and see how i get on
It'll be fine, most of my oil press and fuel connections are like it!
