As above, need the long bolt for the 7.5" diffs, anyone got one going spare.
i believe you can use studding as an alternative - available from any DIY store.
Ned.
DIY store studding probably wont be high tensile, in fact probably not even preper thread but moulded rubbish.
If its the top of the diff bolt i used two M12 hex head bolts and fed them through from the inside.
I got one. FoC + Post.
Screwfix do Stainless Studding. Thats what I've used.
I second bob with the 2 M12 bolts approach. It works a treat, although a tiny bit of metal needs grinding off of the nut that fits inside the diff casting.
using capheads from the centre pointing outwards should required no grinding i'd of thought surely?!
Yup cap heads no grinding
Bolts maybe a tad
