type 9 clutch release lever also,part no for spigot bush to go into a zetec and a gearbox mounting,some tina/landrover engine mounts wouldnt go amis
either,ill be at detling sunday btw
This is the part no for the spigot brg. 1596468. Bought one myself today. 7 quid from ford.
cheers dude
John,
Ned said he's got the clutch release lever if you want it. U2U him.
Rich.
yup, i found a clutch fork and release bearing that I'm 90% sure came off a type9 john. - probably the same one that i sold to chrisw that you now have actually!!
cheers ned,can you bring it to detling
as said in previous post you can have this also.....if i dont need for the hydraullic conversion!
will do jon. i'll put it in a carrier bag as its a bit mucky
