Anyone got a spare passenger side front upright?
The bolt that holds the upright to the damper snapped off without loosening. It's just about scrap now after I've tried to get it out!
i think i have one kicking about, only problem is i wont be over at the garage for a couple of days now if your in no hurry i will have a look when im next there
Cheers, theres no hurry as I am only collecting all the bits from my Sierra. Will not be starting my BEC until after the summer hoidays and after I
find a decent bike engine!
Let me know how much you want. Cheers!!
All of mine snapped. Bugger to drill out due to length and high tensile. I couldnt get mine out without knackering threads so drilled clearance and
fitted longer high tensile bolt with nut on end.
Do your maintenance lads have a small machine shop - might be able to dril easier on miller.
Oh yes! Drilled a pilot hole through no problem? BUT the drill wandered.....
Mine did that. Still managed to drill out M12 clearance and fit nut and bolt. They arent trashed yet!!
Almit metals at Ayclife did a lovely job of de-rusting my donor bits and zinc plating. 2 boxes full for 40 odd quid.
Im in garage tomorrow night (Wed) if u fancy a look over.
I have one available
message me for details
