where is the best place to buy a veypor vr2 display system from ?
I know there was a group buy a few months ago but at the time I was concentrating on other areas of the car.
Thoes who fitted it any comments or pics..
Cheers Paul
I have one, it's a very cool toy.
I'm using a Veypor VR2. 'Tis a good bit of kit, with several functions:-
Tacho, speedo, distance travelled, gear indicator, shift light and g meter.
They also regularly update the software adding new features. They have just added a virtual fuel gauge (with MPG, range etc) and a servicing timer
which you can programme to come up on hours engine run or miles. Last update also added 4-5 different options on the display.
However it does not monitor:-
engine water temp, oil temp, oil pressure, volts, amps, etc, so you would need additional dials to cover them.
I always intended fitting the 3 gauge set from NFAuto once I'd passed the SVA.
It does however have some cool features though, data logging, 0-60 runs, staged 1/4 miles, 50-70 timer, 70-0 timer.
The V-Max feature on mine seems to be broken, either that or perhaps I picked up one of Darrens missing magnets, cause mine was showing 125 on
Sunday.
HTH
Mike
contact hotsotbeans he may be able to sort you out
MK now selling the speedwell digital dash. looks good, you should have a look at it
Ian
