I'm after the above to fit either R1 or blackbird carbs or with carbs but must have throttle position sensor. if without carbs it will need to be
correctly spaced so that carbs will align properly and not require respacing.
I've been waiting 8 weeks with bogg bros and keen to get things moving again.
If you have what I'm after give me a call to discuss, I can't collect U2U easily as borrowing friends wifi as mine is on the blink again.
Alex
07976 700051
Bogg bros called this morning and have come good.
Alex
