Engine and running gear from a S14 or s14a will need alll parts including box,loom,turbo,ecu,key and imobaliser modual
thanks
Welcome to the locost 'tuners' club
You might want to look at a crashed runner, as there are lots of other bits that are useful .... and you can sell the rest on and make ££££
You will need the fusebox too - and the speedo pcb if you want the boost controller to reduce boost in 1st and 2nd, which will be very useful....
And ask on here, an excellent source of cars, parts and knowledge if you didn't already know:
sxoc.com
thanks Jasper, im a member of SXOC so asked a few on there. Its not "that" expensive really but i no what your saying
need to get the immu box aswell and the key if i get the engine from a s14a.
i think it will be easier if i buy a rear end damaged one but there's none about at the moment
