does anyone have a spare gearbox mounting of a sierra ?
The Westfield item is cheap and better than the standard Sierra which is a bit soft
You can buy the middle bit that you need from car spares shop for £6ish.
read this thread and follow the link to the Westfield webiste for their type 9 g/box mount - this seems to be most people's preferred method as
it's substantially better than the original Ford item and inexpensive too.
HTH
Nick
Cliky Click Click here to read the thread
Note: the westfeild mount is not a direct replacement for the orginal on that is used on the MK, you would need to fabricate a mounting.
Dan
Hi,
Ive got one off a Sierra, I dont see where youre from, Im in Chesterfield, if youre close enough, you can have it for nothing.
