re the title, the manifold on the set up i have lifts my carbs a good inch up causing bonnet problems.
so if anyone has a straight inlet manifold to suit twin weber 40's.
thanks
Ewan
What would you like the manifold to fit onto? Setup is a little vague
Might help if people know what engine you are going to fit it to?
It's a ford Xflow
The angle of the manifold is to clear the dizzy.Not sure if you can get dead straight ones.
