hi everyone,
has anyone got a 2 litre zetec fuel injection system handy?
pictures would help!
many thanks,
i;ve got a standard ECU,,
Rau
well if you havent got a use for it I am interested in buying one for a good price. Im Cambridge based...
make me an offer, u2u if you like
Ray
ok mate will do, can you confirm exactly what bits you have? sorry that might just be the ECU unit but Im always learning!
thank you
just the ecu,
Ray
finking...
sorry for the delay but basically im not sure what else i'll need to get the engine running so im not sure how much to quote... its proving hard
to find out what bits I need and how much so i'll get back to you when i can.
(i've had to create a new account, hence username jimbona2)
this is what I have at present, any ideas what i need?
the other side
You'll need an inlet manifold, fuel rail, throttle body, injectors, loom and ECU. Also the CPS if it's not there already (make sure
it's the same one (including the housing) from the size engine that is in your car)
Your best bet would be to find a 1.8 or 1.6 Escort inlet, and fit the Mondeo 2.0 (biege) injectors and throttle body to it. The injectors are a
straight swap, but the throttle body needs a little attention from the grinder to make clearance.
Oh, and use a Megasquirt ECU - far easier than the standard item. No PATS for a start. It is possible on the Mondeo management, but it's a lot
of grief when you can run Megasquirt for ~£100.
Chris
would you recommend this?
FORD ESCORT1600 ZETEC INLET MANIFOLD (LATE SHAPE)
http://search.ebay.co.uk/search/search.dll?sofocus=bs&sbrftog=1&fcl=3&from=R10&satitle=zetec+inlet&sacat=-1%26catref%3DC6&sarg
n=-1%26saslc%3D3&sadis=200&fpos=cb4+5rn&ga10244=10425&ftrt=1&ftrv=1&saprclo=&saprchi=&fsop=3%26fsoo%3D1
[Edited on 26/10/06 by jimbona2]
hi everyone,
i have this now!!
Here 039;s a complete 1.8 escort zetec with inlet and exhaust manifold, £40 with 5 hours to go.
thanks for the top tip but are you saying this is what else i need or its the whole thing in one for 40 quid.
