Could do with a capri axle, somewhere in the leicestershire or surrounding area, must be cheap as it is for an experimental setup.
Could do with it being std and straight off the car with no extra bits welded on, as I will be welding a fair bit on and don't want to distort it
too much.
Ideally 3.75:1 or higher (4.1:1 even better!!!) but anything considered, one with LSD in it from a 2.8i special even better!!!!!!
cheers
Nat
my uncle has 2 for sale in spalding lincs if thats anygood ?
how much, and what ratios (what capris are they from)
cheers
Nat
thought you wanted mine?
still interested Mike, but I am worried that it has already been welded up once, worried that it might be a bit distorted if I cut your brackets off and weld it all up again!
yeah possibly - was only 100 amp welder that did the 'damage' tho.
(can't help being curious if you're doing what i think you're doing with the shell you've recently got)
There's one on e bay at moment being sold by a goat loving shoe fetishist
Hi Nat dont be to woried about distortion one the axle you can re straighten the atlas been doing it in the old group 4 escorts years ago. PLus it is
a bit stronger than the english type.
cheers matt
Chatting to a chat about propshafts at work. If you end up needing a prop shaft let me know, he'll tell you how to modify one. I learned a few
things that i didn't know (ok, so you'll probably already know them!)
Going to have a few rover v8 bits to put on hear for him as well, block, pistons, crank, bearings, starter, timing cover ...... if you fancy going for
a poor breathing 3.5 v8!
Wooooaaah, did i see some more scope creap? He's also got a LT97 box for 4 wheel drive and ......
Nah, XE will do the trick, its sat there waiting to go!!! That's one bit that is sorted!
I'll just need another one then to replace it so the class 9 is a goer again!
