...4mm sheet big enough to make some wind deflectors. I need 2 bits c. 42cm x 20cm, if anyone's got any offcuts going.
Got some for mine from my local plastics supply company, cost about £5.00 IIRC . Yellow Pages?
Now you mention it, there is a glazing company here that also does plastics, so I might give them a try.
Ta
Went round there today and got two wind deflectors cut to my template for a fiver! It's 5 or 6mm so a bit thicker than my screen, but it should mean they are even less likely to bend or break.
