Sierra rear bearing housing/calliper mounting. Any one?
Yes I know I can get plates to bolt on to the drum versions to carry the callipers, but I want to keep the wieght down!
x1 or x2? Will have a look tonight, may have a bare one or two
will need both bud as I dont have any at the mo! Have the drum versions. If ya want Ill swap ya!
btt
if you have the bracket for converting drum to disc i have a set of bearing housing/calliper mounting if you want to swop
Dont at the moment, but Im looking to get hold of a pair. If you can hang on then Im up for a swap!
Ian
Still looking!
