I am getting the parts together for project 2. (Rear engined R1 powered)
I am in need of both front and rear Brake Caliper Carriers from a Rover 214.
The fronts are for vented discs and the rears are singles.
I bought a set of recon calipers from BIG RED brakes, but they did not come with the carriers.
I also want either a Rover or Sierra Colomn. It can be the top section only and I do not require the ignition lock, indicator/wiper switches or
cowlings.
Money waiting
I have the column from a 416GTi, is this any good?
Is it a quite short rod and mounting tube, with a UJ and short rod on the end?
I suspect it is the same as the 214.
If so, u2u me with a cost plus p & p.
Regards Martin
Went to the breakers this morning. They had a fiat punto adjustable colomn.
Bought that!!!!!!!!!
