After just dropping one of these, I don't fancy blending out the dent and then revving to 7-8000 rpm.
Does anyone have a single piston lying around?
Beer tokens waiting.
ATB Dan.
Try the dealers, they sell them in singles, about £45
Trying to keep it Locost, only paid £35 for the whole engine
ATB Dan.
They will almost certainly be graded for size and maybe even wieght so it may be best to get a new one.
Steve.
4AGE pistons are definitely sized and weighted - the code is stamped on the conrod. You need to get the right one to stop the litlle beasty from
becoming a grenade.
I've got the manual at home if you need a hand - though it's also probably available on the www. It might be worth a browse at
http://www.toymods.net/forums/
I have one you can have - what age engine is yours?
Eddy
Eddy, It's a 1985 Mr2 engine, the piston has 2 in it's crown. Where do you want the tokens sent.
ATB Dan.
I'm just about to order some Toyota 4AGZE pistons from Japan via Fensport and they are a very reasonable £33+VAT each.
Allegedly they forged and coated but I'm a bit skeptical about this?
