What are the general thoughts on positioning the front wingsin relation to the tyre circumference?
I know it depends on model but are there any SVA implications other than edging them?
Looking through the comics it seems to vary widely from lining up with a vertical off the front of the tyre to front edge parallel to the upper
wishbone or lighting bracket. Some even seem to line up with the rear lower edge lined up with the front lower edge of the rear wing.
Presumably the further round the tyre they sit = less grit blast to the rear arches?
Cheers, Pewe.
SVA says that a plumb (vertical) line drawn downwards from the front edge of the cycle wing MUST extend forwards of the wheel rim (not tyre)....so in English as long as it comes far enough forwards to extend over the rim you can do what ever you like....Oli.
Thanks, Oli. Should have asked before I drilled those f**cking holes at the weekend! Out with the filler paste /wet & dry tonight then.
Cheers, Pewe
One other thing though, is the further forward you have them the less drag they create. Further back might look better, but for aerodynamics, keep them level.
All I can say to that is............MUDFLAPS
"m*dfl*ps"
surely thats an abusive term and not welcome on this forum
Whilst mud flaps may not look the dogs they must stop grit blast to the rears.
Incidentally I'm looking at a stick-on wing liner which should a) reduce spray and b) stop stones crazing the wing top surface from underneath -
and better than underseal - any interest? Cheers, Pewe
PS well done James - it'll be Krav maga next!
