Evening folks.
I don't suppose anyone has a couple (2) penny washers that have the follwing dimensions that they would accept a couple of beer tokens for?
ID: no more than 10mm, can be smaller
OD: no less than 38mm, but no more than 40mm
Thickness: 1mm or so, a little thicker wouldn't be a problem, a little thinner wouldn't either!
Material is not really important, but stainless, or BZP would be preferable.
Cheers folks
I have some that are 35mm dia, 10mm hole, bought from a kit show, so I guess they could be "standard" size, so you may struggle for bigger
without making your own.
I'll put them in an envolope if you want them?
Col
[Edited on 12/12/06 by ReMan]
If I have a bit of stainless left I will make you two. I'll let you know tomorrow when I've had a look in the garage.
Cheers for the offers folks, much appreciated! I've got it sorted now, managed to get a couple larger stainless ones turned down to size atw ork
today
Cheers!
