Wondering if anyone knows of a good cheap source for engine bit for my zetec....need a top and bottom gasket set, ARP rod, flywheel and head bolts, new bearing shells for the little ends and a piston ring set.....Looked on burton power buts it gonna be a big order a right off my xbox 360 purchase in the january sales if I go that way! If anyone can help me out with somewhere to get some discounted stuff I'd be super grateful! Thanks in advance....Oli.
You could try your local engine reconditioner
Live in Aberdeenshire.....we don't have local engine reconditioners! Tried the usual suspects around here can save a fiver postage but not really any cheaper and not in stock either so no returns etc.....Oli.
seems to be a fair few gasket sets listed on ebay for the zetec.
ARP stuff is usually a bit expensive but does come up on ebay from time to time. shells are a bit more tricky....
Might be cheaper to find another motor - I hear you can pick them up for small amounts of money..
Good luck
Mark
With the way the $ is, get the ARP's from the US via eBay.
