Wanted - the two lifting eyes which screw into the zetec to lift it out.
Edited to say wih bolts would be nice too!
Cheers James.
[Edited on 14/1/07 by jamesg20]
Theres often some nice racey looking ones on ebay.,,,,
none that i can find at the moment
https://secure.encryptedspace.com/autospecialists/cart.php?m
=productcat_list&c=5
Probably cheaper to get a normal set from scrappy or even local dealer, though
Std M8 bolts locate them.....
H Steve,
Are these fitted to engines as standard? The reason i ask is that i've looked in scrappies and none of the engines have them on. I presumed they
were only fitted if the engine was coming in or out....
Well, i simply cannot believe this. I've trawled a couple of breakers... no sign of any.
I submitted 3 online breakers request, one found some, but they sold them before i ordered. I can't believe there is a national shortage of these
little bu**ers....
If anyone goes near a breakers or a zetec and sees any, can they whip them off for me please...
i think i might have some on a black top ( are they the same?)
if so will check in the garage
let me know cheers paul
I think they are the same.
I'm quite happy to buy them off you, or if you want them back, i will gladly post when i have finished. I never thought something so simple could
be so difficult. At this rate i will have to resort to spending £30 on bling! Not very locost...
will go and check in the garage now
but I'm sure Ive gold plated them
oh i hope so....
u2u sent
will post them off in the morning !
hope they fit !
cheers paul
posted,
so you should get them very soon
so did you receive them?
paul
