I need to get hold of a couple of meters of polyamide hose. Does anyone know where I can get hold of this in small quantities? I don't really
need a 30 m roll!
Regards, Ian.
Not sure what size you are after, but Nylon (=Polyamide=PA) tube can be bought by the metre from pneumatic controls specialists (I think RS also stock
it) - normally goes up to 12-14mm o.d.
You might try food handling machine companies otherwise for that and larger stuff.
Many thanks. I've found a place in Poole that does it by the meter.
