After no luck in the scrappys around me.......
Does anyone happen to have a set of injectors (ideally 4 but can make do with 2) for a Fiat Bravo 1.6?
It is the later model that has the plastic inlet manifold. The car is a T reg 99/00 1.6 16v (Petrol)
Im getting a tad desperate now with the car just sitting there.
[Edited on 19/1/07 by SALAD]
Do you have the part number from the injectors?
If its a bosch they start 0 2....
One place gave me a reference number of 28576 which would be useless Im sure, so I then tried to find out from other branches only to be continuously
put through to the same bloke!!
I was then told that he wouldn't give me the part number
