hi guys
anybody got a spare or unused rivnut tool i dont want to make own and dont really want to buy new if i dont have to. did have one not so long ago but
seem to have lost or misplaced rather well was mainly used for M5/M6 rivnuts
if you only have a few to do i can lone you one for a few weeks seeing as your only just up the road
that would be good thank you probably got about 15 to do trouble is it would be between now and 6 months as things are going in as and when they need
to till the end of the build hopefully not long
would probably need it longer than you would be prepared to loan thanks
[Edited on 29/1/07 by myeates]
herrm i know whats going to happen here, i'll need it as soon as you have it, if you could cut it done to say a month its yours, if not your going to have to buy one
yep that the usual thing that happens. thanks for the offer mate appreciate it but dont want to put you out incase you need it will try find a good
cheap one
thanks again mate
MK used to do a machined one, you got it when you bought part of the indy KIt maybe they will still sell em seperatly..
yeah MK supplied me with one, broke on the first attempt
How many rivnuts are you planning to set? If there aren't too many, you can use a length of steel strip with a bolt, nut and washer.
Drill a hole in the steel strip, leave enough for a handle. Grease the bolt, then fit the nut & washer. Put the bolt through the hole in the
steel strip, then thread on the rivnut fully. Push the rivnut into the hole, and start winding the nut down against the steel strip. You might need
another spanner to stop the bolt turning (3 hands are useful!).
This will set the rivnut properly, but will rapidly knacker the nut & bolt - if you manage to set 6 or 7 before they give out you'll be doing
well.
If you have a lathe you can make a fancy one, as described on my website (link below). That one is much easier to use, and lasts for years!
thanks david may try that oneat the weekend will still try and find my other one
thanks all
found it
the stupid thing had slid down behind one of the shelves and rested on the support so i couldnt see it i thought id looked everywhere hehe
god job i didnt buy another one that would of been very anoying
