Pedal Box Wanted
markal - 7/2/07 at 09:08 AM
I want a Cheap floor mounted pedal box, email or pm, regards Alan.
russbost - 7/2/07 at 02:03 PM
Alan
Don't know if it's likely to be of interest, but I've just developed a new pedal box for the Furore F1. Mine takes Toyota master cyls, but could fairly easily be modified to fit whatever you want, it's only really the front plate which would need replacement/modification. I could do you the set of lasercut parts to weld up the box yourself for £25 + P&P, the other bits are just tube (for pivots) & some 25mm square for the actual pedal bars. The pedal pads & even the clevis pin locations all come laser cut. There are some pictures in my archive of the pedal box both bare & assembled. Let me know if of interest. Cheers Russ
cct7kitcars - 7/2/07 at 02:14 PM
russ how much for a bulk buy of theses pedal boxes
joe
russbost - 7/2/07 at 03:20 PM
Blimey
How much cheaper than £25 do you want How does £24.95 sound?
If the quantity is high enough could get a fresh front plate designed & cut for whatever cyls you want if that helps. £20 each for 20 units or more. Bear in mind you'll need to supply your own pivots & pedal arms as these aren't part of the lasercut package.
Russ
cct7kitcars - 8/2/07 at 11:26 AM
make it 15 quid and i will have them
