Loan of an old Kent block.
A friend of mine's doing a rather interesting project but he needs the dimensions of the Kent block's engine mounts and gearbox face.
Either a 1300 or 1600 Kent will do, (or even the 1100 if it's the same dimensions).
Even engineering drawings of them would probably do if they have a comprehensive set of the necessary dimensions.
He'd only want it a few months, and a knackered one would be fine as the car's actually going to have a Ford BDA engine when done (the Kent
is same mount/box layout). So you can have the block back when he's done if you want!
Thanks!
James
EDIT: I should add, hopefully somewhere in the South East.
[Edited on 12/2/07 by James]
Got one in Cambridge he can borrow , would like it back at some stage
One in Oxford James, Sorry it no closer.
ATB Dan
I Have a 1600 block in a wonderful shade of green & rust in a shed in Alton.
It probably wont need returning!!
James try stevem he has blown a couple
Although alton sounds your closest so far
Thanks for all the offers everyone!
Appreciate it.
I'll be in touch!
James
Ooooops sorry James .....
Forgot to go for the rummage.......
It must be the cold/flu ...or whatever.......
Deffo u2u tonight ......
Many apologies again,
Fozzie
James u2u sent
Fozzie
