Hi,
Im after the little plastic bush shown in the picture below. they have the full linkage on ebay but not wanting to spend £60!!!
The bracket model number is 74BB9K819BA
If no one has once any suggestions where i can get one?
Image deleted by owner
Henry ford still have them
Dave
Sad this havin worked at ford dealer 10 year ago i can still quote that bushes part number 1584303 may well save you time cause they wont know what
your on about
Good work ash
cheers
Paul
65p from good old henry
Does Henry Ford still stock the above? Or any one have the part No.? Its a slide clip holding the ball and throttle cable together.
Burton Power do them for 75p, go to www.burtonpower.com, then sundries & miscellaneous items, throttle and speedo cables, Escort MK1. The part number is TCClip.
