4 Spark plug Adapter Inserts that convert from the Std 18mm Pinto Spark plugs so that I can run 12mm Motorbike spark plugs required, cash waiting.
Alex
Do they make them?
Yep,
li
nky
SpeedPro Pinto tuning book also mentions them if you raise the CR significantly.
How does the plug hit the piston, plugs don't move? Why is the spark better from a bike plug? They run on the same electrics as the other plug. The only thing they are doing is taking the spark outside the combustion chamber, can't you get shorter reach 18mm plugs to do that?
No longer needed, short tip plugs are the solution. Part number NGK A7FS.
