thick ali wanted
snippy - 23/3/07 at 09:14 PM
I`m after some scraps of thick ali if anyone has some. 6mm thick or even thicker preferred. It`s needed to make up some thick ali spacers to go under the engine mounts to lift the engine up higher.
a piece 250mm x 150mm would be sufficient but anything considered. Beer tokens can be supplied.
Thanks,
Nick
blueshift - 23/3/07 at 11:37 PM
Sounds like pretty miserable, selfish vandalism to me. Thumbs down.
Go and get a bend ladder from the tip if you want something to chop up for cheap.
[EDIT]
This post was in response to someone who was suggesting stealing road signs and cutting them up.
Apparently they have been shamed into deleting their post. Good! Naughty!
[Edited on 24/3/07 by blueshift]
Macbeast - 24/3/07 at 07:02 AM
Isn't "thick Ali" a bit racist ?
ReMan - 24/3/07 at 10:56 AM
I may have something that will do you, see your u2u
