As above - looking for the bush that cancels the indicators on a Sierra Steering Column.
Cheers.
If you can't find one you can drill a shallow hole in the column and weld a suitably fettled bit of metal in place. Works just as well....
A Momo boss (and others afaik) has this built in.
Have a slightly damaged one you can have. The tag that sits in the boss is broken of.
I've got the Mountney boss and it doesn't have it... so the main problem is the column is loose in the mount, need the bush to make up the length.
I may have one in working order. Send me a U2U to remind me to let you know tomorrow. If I have, I'll chuck it in the post.
Memory like a sieve!
u2 Back....
