The pics below show my left and right rear upper wishbones. The left seems to have lost its locknut on the bit that does the camber adjustment. Does
anyone know what size this is and where I can get one? Please ignore the liberal coating of CV joint grease! TVM
leftrearwish
rightrearwish
herrrm, i'd best check mine tonight as i'd lost one even before sva, i called mk and they posted me one.
That's a result. I was going to ring them first but the thought of sending them a cheque for a single nut was holding me back!
Just rung 'em and it's a standard 20mm half nut. Job done.
[Edited on 1/6/07 by Jubal]
If there's one part of the car that needs to belt and braces appraoch to threadlock and lockwire, it's those nuts!
I've heard a couple of stories of people finding a rear wheel seriously out of shape only to find the nuts had loosed competely off - not worth
thinking about if it happens at speed
If there's one part of the car that needs to belt and braces appraoch of threadlock and lockwire, it's those nuts!
Originally posted by StevieB
I've heard a couple of stories of people finding a rear wheel seriously out of shape only to find the nuts had loosed competely off - not worth thinking about if it happens at speed
Loctite, lockwire, welded, tie wrap and cover in black nasty (just to be sure!)
We replaced ours a with a nyloc.
Simon
Simon
Simon
Both nuts with one nylock?
nyloc nuts, i'll second that .We lost one nut on our indy and replaced the nuts with one nyloc no problems since.
