160mm long and M10 1.25 pitch!
An alternative would be a longer M10 bolt that can have the shank re-threaded to 1.25 pitch.
It is for my R1 engine.
I would rather the correct bolt size than re-threading the engine block.
Cheers Martin
how many
material. ie stainless or mild steel H/T
how many
Martin
Ttry Fast Fix Direct - usually have that sort of thing
Do a google for them
Peter
Tried them.
I think that I am fcuked!
Max length is 100mm.
It looks like I might have to rethink my fixing points on the chassis.
Try PFS in Arborfield 0118 932 8832 do all sorts of stainless and used to supply Xtrac, failing that AHC Camberley 01276 709069 are helpful. Good
luck, Pewe
http://www.a2stainless.co.uk/M10-x-1-25-x-115mm-Socket-Capscrew-A2_AEE5.aspx
115mm long is the longest i found
or 160 but as a bolt head
http://www.a2stainless.co.uk/M10-x-1-25-x-160mm-Hex-Bolt-A2-_A92P5.aspx
[Edited on 6/6/07 by Aboardman]
Pewe, thanks for the numbers. I rang both and they are going to try and locate some and will ring me back in the morning.
I am keeping my fingers crossed !
Aboardman
just seen your post. I can change to hex head, perfect thanks!
I'll try my local fastener although I wasn;t successful last time I offered this service!!
cap head in 160mm long and M10 1.25 pitch, fully threaded or else a set screw (fully threaded) in stainless.
is that ISO thread or some fine/coarse variant?
try willenhall fastners they are very good and can get specials mad can't remember there number though!
Get some 160 M12's turned down to correct diameter, and then I can lend ya an M10 x 1.25
die.......
i will know by morning, will let you know
