I'm after the rubber sock that goes between the track rod end and the hub fixing. Ive got the rubber gaitors but dont know what the other bits called
If its the area im thinking of i fitted split convoluted tube and secured with cable ties for SVA. I think some others may have used shrink tube (not
sure if this is good to cover the hex though).
[Edited on 22/6/07 by DarrenW]
you can use a armored cable gland cover fron any electrical factors
eg city electric, edmonsons etc
