As above, either will do with the bolt on flanges.
Looks like there will be a franzy for this NOS part and doesnt even stsate if its LSD.
Diff
Strange thing is even though it has a nice white lable where is the nice new diff tag also the breather and pipe is missing ??
For a part allegedly never used why are these bits missing ?
They both use diff size drive shafts so you need the ones that match your outer hubs so which ones are they?
Splines are the same shafts are diff sizes.
Basicly the 7.5inch diff (cosworth) has bigger flanges and larger bolts.
The 7inch ( normal sierra) smaller ones.
Although there is an exception to every rule the granada cosworth has a 7.5inch diff with the smaller flanges.
I know this as i have just done a diff change on my brothers 4i that has full cosworth running gear and the only diff we had spare was a granada
cosworth one and we had to get the flanges swapped over.
There's a 7.5" 3.36 with LSD for £200 on the Westfield forum (www.WSCC.co.uk
I have 2wd cosworth diff from a 60,000 mile car, 7.5 lsd 3.64 ratio, I have removed the rear lug on the diff cover, so it needs a little plate welded
or rivetted on
The inside of the diff is sparkling, the oil crystal clear
£120 Chandlers Ford, Hampshire
[Edited on 10/7/07 by Minicooper]
hi all iam in the proses off braking a sierra XR4X4 on a 1988 the diff is a 7" and bolt on shafts was going to keep as a spaire its still in at
the momo but its yours if you stuk
my email is hotrodbob@hotmail.co.uk
[Edited on 10/7/07 by repper]
