Hi All
I’m fitting a data logger to my single seater and would like, at some point, to be able to measure individual wheel speed. The unit
(Race Technology – DL1) will measure actual speed using GPS and the accelerometers, and
gearbox output speed using the gearbox sensor, but measuring wheel speed will enable me to look at wheel spin or lock.
Being tight, I don’t want to spend too much on wheel speed sensors so I was wondering if anybody has a set of four ABS sensors they may have stripped
off their donor. I'm hoping these would work (after suitable mounting) as the DL1 accepts most types of sensors and can be easily programmed).
Beer tokens waiting.
Regards
Wyn
i have a pair of sierra front sensors if you want them
I can supply the other two from my car, but its not a sierra!
In case they don't match, I have a full set of four anyway
Toyota units which I believe are 'Nippon/Denso' items
Thanks Guys
I've just bought a set from SteveC who U2U'd me.
