i want some cheap nasty headlights so i can get thru the SVA, as i don't think i will pass with my 4" motorbike ones i bought from GTS Tuning
Premier Wiring, budget lamps £25 per pair.
http://www.premierwiring.co.uk/index.php?module=Website&action=Text&content=1133393686882-8823&parentContent=1133392767901-3830
HTH
Mike
brilliant, i've not seen them before. thanks
I'd just check how it "converts" from RHD to LHD and vice versa. It doesn't state that they're SVA friendly and the "convertability" may mean they're not.... Worth checking with SVC before buying (they're pretty good usually)....
I know that gillingham in kent have passed the GTS lights without any problems but i dont expect you'll be taking your car that far!!!
any local car owners you could borrow a pair from just for SVA purposes.
borrowing not really an option, i will phone them up tomo see if they are sva OK or not, not sure about risking the lights i have or not really.
can you post th results on here, as i am also in the same situation and am unsure wether to try with the 4" headlights.
cheers james
think i might buy some cheapy ones and wiring them up as standby so they are just plug and play, then cross my fingers on a nice examiner
Those are even cheaper than the pair of 2CV lights I got!
Caber
