has anyone got 1 for sale or recomend a place toget one from
would like one with unleaded reducer
thanks
i've used one of these on mine and fitted my own unleaded reducer using a spare reardriveshaft washer temporarily secured with a small amount of
silicon sealant so it can easily be removed after SVA
http://www.demon-tweeks.co.uk/products/ProductDetail.asp?cls=MSPORT&pcode=MOCCAP3ZF
Europa sell a nice little one for around £40 iirc.
Thats the one i used but i paid the extra £13 for the unleaded reducer.
Bigrich is obviously more ingenius than i
I have the eropa £40 jobber with the unleaded reducer... looks really nice, the only problem with it is that it is not vented.....
If the reducer is vented do you then need a seperate tank vent as well?
The reducer is just a ..... reducer. It simply sits in the filler neck and is secured with a circlip. tbh I don't think any of the Aero caps are vented so you will need a tank vent in any case.
Do you need a reducer if you say to SVA it's an old Pinto and you use LRP ?
My reducer is vented. So if it is do i need another tank breather?
Your right its not so id better get one
Ta
link to the europa one anyone?
https://secure.visav.co.uk/avshop/products.asp?getcats=true&cat=31&scat=72
