Like a tw*t I managed to break one of the mirrors which I had prepared to screw straight into the 8mm threaded hole which will eventually be occupied
by my upper windscreen mounting bolt.
I tried replacing the glass with some of that plastic repair stuff. Looking into that is a bit like I would imagine a bad acid trip so I don't
think the man would be happy!
Anyone help?
IIRC some of the motorbike mirrors have a m8 fitting. If so there are some cheap mirrors out there..... I used the cub70 succesfully....
Which side did you break?
I've got some cub70 ones for beer tokens...
Ben,
You have U2U
Mike
