Mate of mine needs x-flow dizzy (1600) for his 7.
Destroyed it at Spa on a trackday.
Cheers, Andy
Look for a MK3 fiesta in the scrappers, they're electronic ignition (no points) too
I might have an suitable (but old) points dizzy in the garage, if that's what you want. Used to work, before I fitted a Valencia dizzy, which
was in turn replaced by Megajolt...
Whereabouts are you?
I have a Bosch type - looks in good condition but never run by me in anger as it won't fit under my twin carb manifold on 1300 engine,
make me an offer I cannot refuse
Thanks all,
Had a word with the fella and it looks like a trip to the scrappers for a mk3 fezzy for him.
Top fella's, good show
If you do that, make sure that it comes with the little module that's screwed to the side, together with the connector.
You'll need a different coil, so you might as well salvage that as well!
You might find this link useful, too.
It's a worthwhile upgrade - it gives you the equivalent of perfectly adjusted points all the time.
[Edited on 12/9/07 by David Jenkins]
Bonza,
Stars one and all
