As per the title, does anyone have a blown up engine for the old ZX10 (89-90) or the ZZR1100. All I want it for is a dummy engine to use for setting
up the mounts for an engine cradle, would be handy if it had a head on it to give the overall height but a bare bottom end would do (I can make up a
dummy head measuring off an existing engine). If it's empty of bits all the better as it will be lighter. Happy to part with a (small!!!) amount
of beer tokens + Postage. It will give you more space to work in - honest
u2u or email russ@furorecars.co.uk
Cheers!
[Edited on 20/9/07 by russbost]
It just so happens that I do!
It'll be the weekend before I can get to it.
I'll weigh it first and let you know likely postage costs.
HTH
Mike
Mike
Thanx that would be great, please keep me informed.
Russ
If you need any other parts I have 2 complete but broken engines inc. looms ecu's and carbs.
If anybody has a spare crank they would like to exchange for beer tokens I'm looking for one (sorry for hijack
Reagrds
Davie
Davie
I have a spare crank. Not sure if it would be any good to you though. It span a bearing (no 3). Crank doesn't look scored or rough, but
I'm no engineer / expert. I'd be happy to post it up to you (if you'll cover the postage!) and then if it's useful to you then
you can make a donation. If it's FUBAR then you are only out the post?
P.S. Do you want to sell / swap a set of carbs?
Mike
