Does anyone have a distributor or know the where about's of one. mine has that huge ecu type box and has had it. will try and fit a later type
dissy.
Any hel greatly appreciated.
Have you already wired up your system and had the car running? i recall that there were a couple of people wondering how you do this.
The easiest system is the earlier inductive type electronic. Thats what i used before switching to megajolt.
You dont have a pic do you to help identify what you have / need to replace?
its a part built kit I have bought and all the wires have been hacked off the dissy and box.
might have the distributor in a week or two but my ecu is also duff, see above post !
Just had a thought, If your dizzy is duff then there's a good chance mine will be but it's here if you want it
where are you ?
