hayabusa/zx12r/ wanetd with all running gear,
also posibly if i get sorted a 929 blade engine already in my kit with all running gear exept rad
Here's aZX12R on
e-bay
to keep your eye on.
Or a Busa engine also on
e-bay
Then there's also Mal from Yorkshire Engines
Phil
[Edited on 4-1-08 by Hellfire]
there's a 12R here for not alot of money http://www.pistonheads.com/sales/304093.htm
What were the clutch issues????
Planning on a Zx12 for a future project
Ta
The 2000 & 2001 ZX12R clutches lacked oiling. This was rectified in 2002 when the inner clutch hub and basket were re-designed. The oiling issues
sometimes caused the clutch hub to break and/or clutch baskets to explode. The inner hub of 2002 models onwards has more holes drilled which improved
oiling.
Phil
Which probably means that if you buy an '00 or '01 motor it could be rectified by using a later basket?
Definately worth giving Malc a ring before you buy anywhere else
