NEED THE REAR OUTER CV JOINT x 2 FROM SIERRA COSWORTH, 4X4 ,GRANADA & THE STUB AXLES THAT GO THROUGH THE HUBS & BOLTS PLEASE SO I CAN PUT MY
LSD IN ,IVE GOT THE INNERS & DRIVE SHAFTS ,W.H.Y. CHEERS
[Edited on 10/1/08 by Ricks-9r]
Standard Sierra should fit - I've got a cossie diff with granny drive shafts and sierra hubs - pretty much all mix and match?...
any rear disc sierra stuff will fit.
I have the bits if you can't find them closer.
U2U sent
sierra will fit, my thought was that escort is bigger (wont fit-i know it isn't mentioned-)
cheers
Tks
quote:Ive got the parts i needed now ,Cheers any way
Originally posted by Ricks-9r
NEED THE REAR OUTER CV JOINT x 2 FROM SIERRA COSWORTH, 4X4 ,GRANADA & THE STUB AXLES THAT GO THROUGH THE HUBS & BOLTS PLEASE SO I CAN PUT MY LSD IN ,IVE GOT THE INNERS & DRIVE SHAFTS ,W.H.Y. CHEERS![]()
