Looks like my runabout's ecu has some problems - Keep Alive Memory has got amnesia
Anyone got one?
what is that is it a cvh or zetec
[Edited on 30/1/08 by dave-69isit]
It is actually a PTE and apparently a bit rare
CVH development then.
I had a 1.3CVH which looked identical to a 1.4 so it might be worth a look. You could find one in a Fiesta which used the 1.4 as well. The one I had used a spark amplifier on the side of the distributor, nothing fancy like memory or ecu though.
Looks like I have found a suitable ECU but it has ocurred to me that it will not be a simple swap.
Do I need to do anything about the key codes or is that too sophisticated for an Escort?
