as it say, looking for some small non-electrically conducting screws, e.g. from nylon but 2.5 mm or 3 mm. need 6. would be helpful to have nylon
nuts too but I guess steel ones will work, assuming same pitch.
anyone know of a cheap source?
and thermal conducting glue? may try a DIY version of 2 part epoxy with copper filings mixed in.
Anyone tried this? What short of proportions would I be looking at to achieve good stickness and good conductivity? 50/50? more? less?
oooh. so many difficult questions for a Friday afer noon....
RS do them, in bags of 100 - anybody after 94 nylon bolts???
why do they sell nuts in 50 bags but bolts in 100??????
[Edited on 8/2/08 by 02GF74]
http://www.rapidonline.com/ will have what you want at a very reasonable price
IMHO, copper filings and glue wont work too well..
Just use normal glue with a wire to provide electrical conductivity
[Edited on 8/2/08 by tegwin]
I've seen the metal filings used before, it does work. Depending on the load you can mix a lot of metal in over 80% weight for weight as the
particals only need a microscopic coating to bond them. In modelling I use tiny hollow glass beads in epoxy to make a strong kind of filler.
[Edited on 8/2/08 by Mr Whippy]
try www.modelfixings.co.uk for nylon bolts and nuts etc in small quantities. They sell all sorts of small fixings and bits!
