Hi all
I am in need of buing a dremel but there seems to be so many different types.
What would anyone recc? prices etc
cheers colin
Originally posted by hector
Hi all
cheers colin
As Above!!!
Bought mine for £15!
bought mine broke it, got a new one broke it, got a new one! the don't like stalling!!
what sizes shank bits do they take?
reasonn i ask is i have a few rotary burrs with 1/4 inch shanks, will these fit?
cheers
i got a woolies 1
and its faultless
used it to cut holes in body for exhaust etc one of the best tools in the shop.imho
also got a bit kit from aldi with cutting discs hole fetlers etc top piece of kit
I bought a cheapie B&Q jobbie with about 100 add-ons for less than £20 and its still going strong despite being regularly abused. Dremel are overpriced and play on their trade name imo.
Maplin has an offer on, was £29.99 now £19.99 for a dremel copy in a little metal case with about 10 different types of accessories, comes with a
FREE 400 peice accesory set in a natty little case which is normally £19.99 on its own!
It stalls when you try to cut through 2mm steel though....
OK then
Thanks for all the replies.
B n q it is then
i have one of the balck and decker ones, had it for quite a few years and much abused - and one broken spring later, easily to fix, it is still running.
ive had my dremel for.....god knows how long. gotta be at least 15 years if not more.
cheapy ones wernt around then...lol
and it still going strong and boy has it had some abuse.
I had a couple of cheapie ones and they broke, well I broke them, then got a Dremel and it's 100 times more robust. Did all my head work with ome and still working like new...Get what you pay for in this case....If just for some cutting of soft material or light sanding the cheap ones are OK.
