Downpipe to suite the cast manifold as below wanted, anyone got one left over from their donor? only need the flange and a few inches of pipe.
Cheers.
Pete.
I've got the cast flange bit that then becomes a taper cup type connection about 3" down. Your's if you want it.
adrian
Sounds like it will do the job, going in the MGB, so as long as I can weld a couple of bends on it'll be fine.
You ok Posting it? how much do you need?
Cheers.
Pete.
Its a cast oval flange with 4 bolt holes slightly ofset from the ends/corners on the manifild end. 3" casting then got a 2 bolt flange with
2" pipe through it. Total length 5". Came of an early Mondeo and has been sat on a shelf for years gathering dust.
I'll send it today if you want via the firm next doors courier contract. I won't know how much till later (if he ever gets around to letting
me know!) but probably not more than a fiver.
u2u me your address.
