Carb ballancer
austin man - 7/4/08 at 09:43 PM
Just had to reset my twin 40's does anyone in the Rotherham area have a carb balancer I could lend ???? to ensure correct air flow
a gas analyser would also be nice (pushing it a bit me thinks on that one)
britishtrident - 8/4/08 at 07:26 AM
Using a tube as a stethoscope works better on twin DCOEs than a carb balancer.
Trick is to hold the end of the tube at exactly the same relative position for each venturi.
David Jenkins - 8/4/08 at 07:54 AM
I used a length of hose to balance my 4 bike carbs - when I eventually used the proper tool I found that I'd got pretty close with the hose-in-ear technique. Not exact, but not too shabby either.
Backfires make you jump though!
[Edited on 8/4/08 by David Jenkins]
r1_pete - 8/4/08 at 07:54 AM
Do the carbs have vacuum take off's? if so I have a set of gauges for balancing bike carbs... S26 area very close to you.
02GF74 - 8/4/08 at 08:23 AM
car balancer - listen for an even beat in the exhaust and you have it right.
austin man - 8/4/08 at 08:10 PM
hav tried using bike carb balancer but dont have vacum take off these balancers caused the carbs to flood. Thanks all the samew. Looks like ear to the ground then
