Looking for some bonnet clips, much like these:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=260227002401
Except they seem a little pricey (apologies if they're anyones on here, I stand to be corrected!) But then again I can't find any anywhere
else to compare to!
Thanks.
they used to be on ebay for about 10quid for 2! but cant find any now! i am also in need of a set too! sorry i am of no help.
atb
Rob
car builder solutions page 7
Mark
No problem rob, thanks for the reply!
Mark, thanks for that too! I don't need to pass an SVA with the ones I purchase, would anyone recommend any others that they use or know others
have successfully? The ones I currently have are the rubber pull tab through a metal sort of "u" shape, but don't hold in place even
when the car's stationary!
have a google for protex.
top quality stainless over centre latches
caterham and westfield supply them if you require testament to their quality.
they deal with the public. fast service. i replaced my rubber ones with sprung stainless ones. not looked back or worried about flying bonnets
since.
tom
Tom, thanks for that! They certainly have a much larger range than anywhere else I've seen.
Not to be a pain () but is there a paticular type you'd suggest? The sprung type looked interesting, or is that just a terrible idea?
edit - Just re-read your post, I may end up going for the sprung ones then. I'd assume they allow for some play, while also staying locked in
place, sounds good!
[Edited on 9/4/08 by madmandegge]
i may have mislead you slightly.
they're over centre style, but the lever to unlock them is sprung down into the locked position.
if i can find them in 5 mins, i'll stick a link to them. if not, it'll be a bit later.
tom
ETA link: latch
catch plate
latches are £4.13+vat each
catch plates are £0.94+vat each
[Edited on 9/4/08 by indykid]
hi folks
i have a couple of sets of these clips ,
i bought a box full at an auto jumble last year.
£3 each plus potage.
g.gilo@yahoo.co.uk
regards graham
