I need a foot or so length of ali tube to run between turbo and intercooler - any ideas where to get it from?
60mm is an odd size, 57mm is the norm. if this is ok then you can buy 1 metre from paceproducts for about £12! Not cheap but they will also swage the ends for a few extra ££.
Cbs does 63mm OD Aluminium Tube
if it helps
stuart
Thanks chaps, I've got 60mm silicone pipes, so better with the 63mm then....
Jasper, have you looked on eBay?
A quick search came up with this chap who sells a few variants...
eBay
link
Biggest round looks like 60mm OD with 2mm wall so 56mm ID. Any good?
Not sure if the prices are good but didn't make me fall off the chair.
Ebay one looks good, thanks
:0) I've just done this job today, I got my 60mm from ebay, came the next day.
