anyone got a timming cover for a v6 cologne 8 of the water pump bolts sheared and corroded in . tried drilling but not going well !!!
going to try the local engineering shop but need the car back on the road quickly !
john
Bump
Anyone got one ??
can you weld a nut onto the remains of the bolts ? the heat from welding and being able to apply leverage often helps.
